ifownlee41nite@mac.com
Hello, For all of those DIY buffs, and not so DIY buffs here is an easy inexpensive way to get the most quality lighting for you buck!!!
3000 watts for of quality lighting for under $275.00. Check the pictures of the unit. http://www.dvxuser.com/V6/showthread.php?t=95460&page=2
To build on that I recommend you do a very simple but very helpful task. First off there is a lighting manufacture that the Home Depot or Lowes ( I can't remember which because I shop at both so often) carries call UltraTech. I recommend them for the even flow of brilliant light. Once you take the small cage attachment off of the face of the fixtures you will see no obstruction in your light path, just an even flood of light. Get 2 of the 1000w tripode lights (thats 500w for each light) and that will give you 2000w to play with. Next pick up 2 of the single 500w stand alone lights for high lighting the back areas of the set, or what ever. Next and final go to
http://stores.ebay.com/Fotodiox-Direct and buy 2 light shade (flags) adapters for positioning your key light. You will then take the flags off of the shade adapters and afix them to your light stand lights by use of a drill, & some metal tapping screws. Next is the simplest part of all. Get yourself some fine grain sand paper, open up the front glass panel of the light fixture, and sand the inside glass of light fixture until it looks just like smoked glass. This softens the harsh brilliants of the work lights. Close it and you got yourself a hella set of lights man.
Do it. You won't be sorry. Now you have an 3000w light set up for under $275.00.
You can't beat it.
And if you can let me know:beer:
You can't beat it.
