Marshallarts
So I bought an HV20 but the store I bought it from did not have a UV filter. I couldn't resist turning it on anyhow without the UV protector, didn't do much shooting, just tested it out a little.
2 weeks later, having held out the whole time because I wanted to make sure I had the UV protector before I used it, I finally got the filter.
I'm being very paranoid about messing up the lens with fingerprints, scuffs, etc., and one of my questions is am I being too paranoid? But the morning on put on the filter I wanted to first make sure there was no dust on the lens. I gently blew on the glass holding the camera upside down. Sure enough, with my luck, I accidentally spit a little on the glass!!!! AHHHHHHHHH!!!!! I tried to blot it with a lens cloth but it just dried into a speck bluish in color (probably because of some optical reason). I was so upset.
Using lens cleaner and tissue I tried to clean the glass but it only smeared everything, a long circular blue streak across the lens. Being so upset and admittedly compulsive (more than anything I wanted a perfect lens, I've been waiting years for a new camera so that I can properly protect the lens with a UV filter), being so upset I attempted to clean the lens multiple times hoping to get the perfect glass I remembered when first opening the box.
Holding the glass under a light, still after many cleanings I see tiny specks on the glass. Like tiny dried solution marks. I'm not 100% sure the glass is perfect right of the box anyhow but wanted to ask any experts out there if they know. I assumed one should never clean the glass if they can prevent it from getting messed up in the first place. Does lens cleaner take away any sort of protective coating?
