staygettin
i want to make my own field monitor. anyone have any ideas on where i should start ( lcd, portable dvdplayer etc.) i want to get a good visual quality.
thanks ahead of time.
siniarch said:yup. I was looking into doing this myself. I had found an 8.4" lcd which I purchase (and now I have to return) which has 1024x768, had component input on the controller board, zoom pixel for pixel (and even more if you wanted) anti-reflective coating, wide angle view, etc... everything you would ever want.
Unfortunately the company faild to mention that the controller card does handle images up to 1900x1200, but not through the component input. so I waisted all my time with them.
I'll also keep looking Richard.
Luis
Hmm. I wonder what would have to be done to the signal before it could be dumped into the normal path to the monitor? Is it that simple, or would you lose all the zoom functionality, etc. just because there is too much data?siniarch said:the controller card does handle images up to 1900x1200, but not through the component input.
Bvll!tt said:I was just on another thread about a possible dolly cart at big lots and while I was looking through the ad I found this;
I hope it helps, Im thinking of picking one up!
</IMG>
ifownlee41nite@mac.com said:I have this monitor. It has really bad resolution, but if your only looking to use it as a reference monitor I would recommend you turn the color control to black and white. It will give you a sharper image reference for focusing.
siniarch said:Richard,
I don't think they are so narrow minded. The monitor can also be used for computers. it really did have a lot of inputs. VGA, Composite, S-Video, DVI, and Component. But the problem lies in taking analogue footage and converting it to digital. their controller board doesn't handle that when in HD resolution. When I outputted from the camera's s-video it worked great.
That's why its such a shame to not have our beloved camera (hvx) output in hdmi or dvi or something digital.
Which brings me to the next question.
JMC, What has to be done to the signal is process through a board that converts component to VGA, or DVI or HDMI, etc... There are solutions out there, but they are expensive $300-400. plus they add another component that needs to be powered. Now it won't look professional, will need a second battery to power, etc... No one is going to spend $1500 to get a cheap looking solution.
Therefore, until I find another manufacturer that handles all our needs, I'll just have to put the project on hold. And as one friend told me "concentrate on making films, not equipment".
