cardmaverick
A few days ago I posted a teaser tutorial for my developing lighting website. Here is a link:
http://www.dvxuser.com/V6/showthread.php?t=93238
The teaser used a DSLR image as an example of a very important principal in digital cinematography, "exposing to the right".
Many found the tutorial helpful, however some wanted to see an example done with video, as well as see the lighting set up.
Here it is!
I recreated the photograph using an HVX-200 and M2 adapter. I shot with a Nikon 50mm lens. The format was DVCPRO HD 720p 24p. And yes, it stars me again, LOL :cheesy:
Final Clip:
http://www.chrisnuzzaco.com/final.mov
RAW Clip:
http://www.chrisnuzzaco.com/raw.mov
Comparison Clip:
http://www.chrisnuzzaco.com/comparison.mov
Lighting Setup:
The first thing I do with every setup is ask myself this simple question:
"Where in the world is the light supposed to be coming from?"
For this, I decided it should come from the side, and be a soft light that gradually falls off into a dramatic shadow.
Knowing that I would be using an M2 I automatically grabbed my biggest light, an Arri 2k. I set it up a few feet away from my
sitting position, and put grid cloth a few feet in front of it.
Next, I setup a light stand in the spot that I would later occupy and put a neutral colored hat on top. This hat became my subject
to light.
NOTE: I'm about to dive into some exposure settings... I have many methods for figuring it out, this only represents one of many! I also do not get into the technique, thats
a subject for another day!
I took a spot meter reading off of the bright and dark sides of my hat. It read about 4 stops difference. definantly a little too much for what I was going to do in post.
I then set up a reflector on the opposite side. I had a new reading of about 3 2/3 stops. Not much improvement, but I knew that other lights
would be coming into the equation and changing the ratio, so I let it got.
Next were my back lights. I had two. One for my face (650 watt fresnel), the other for my shoulder (300 watt fresnel). I set these up to act as rim lights on my darker side.
They read about 1 stop brighter than my key light reflectively. By this time my shadow side was only 3 stops darker than my key reflectively. Just right. I set my exposure via a
reflective reading from a patch lit by my main key. By the way, flag 2 in the diagram is keep light from the 2 K off of my lens.
Camera Settings:
Pedestal +15
detail level 0
V detail level 0
detail coring -2
chroma level +7
chroma phase 0
color temp 0
gama cinelike D
matrix cine-like
skin tone detail 0ff
operation Film Cam
180 degree shutter
24 FPS
camera f/stop 2.4
Nikon 50mm f/stop 4.5
white balance preset 3200 K
The WHY?
Why +15 on the pedestal and +7 on the chroma level? Post. Thats why. Flexibility. Thats why. The camera compresses my color, so I better start off with as much as I can get right? Right.
Because I can always desaturate without hurting the look of the footage. As for the pedestal, it's all about exposure flexibility, and pixel quality. A bright recording is cleaner than a dark one.
So I chose to get as much information as I could.
Post:
All posting done in After Effects 7.0
Simple curves, and color balance. I also tweaked the blue in my shirt. I would get more into this, but I'm gonna hold off and save it. Plus it also takes a while to explain if you
have never used After Effects before. By the way, I did mask out the flags and diffusion, not enough room in my room....
Here is a simple diagram of the lighting setup:
Even though this tutorial was a bit quick and dirty, I hope you enjoyed it and learned something from it! The future ones will be much better and feature some on set photos. One of my goals is to create come quicktime VR's of the sets so you can "walk around" the set up. I'm also planning on pulling a video capture from my desktop for the posting work, complete with audio description of whats happening.
Thanks for reading!
Here it is!
Final Clip:
RAW Clip:
Comparison Clip:
Lighting Setup:
to light.
Camera Settings:
Pedestal +15
detail level 0
V detail level 0
detail coring -2
chroma level +7
chroma phase 0
color temp 0
gama cinelike D
matrix cine-like
operation Film Cam
180 degree shutter
24 FPS
camera f/stop 2.4
The WHY?
Post:
Thanks for reading!
