New Final Cut Studio 2: I just died
Kholi
Section Moderator
Omg. Final Touch is in Final Cut Studio 2
Motion 3 is embracing 3D!!!!
HOLY CRAP!!!!!!! I died and went to post processing heaven.
SD, HD, and 2k color grading. Holy mother of .... I want it now.
FINAL CUT STUDIO:
-wanted it to be the biggest upgrade ever
-FINAL CUT STUDIO 2
-Final Cut Pro 6
PRO RES 4:2:2 codec
-10 bit 4:2:2
-full raster
-uncompressed project was 1TB, converting to highest quality was 170GB
-bandwidth efficiency, gotta work across a SAN OK
-color space headroom - 4:2:0 converted to 4:2:2
-support for next gen devices
-edit friendly
-translates whatever may come
-SONY - introducing new HDCAM SR system, 1080p60 w/ProRes 4:2:2 will be a good solution according to Sony
-to use that 1080p60 stuff, want it in an edit friendly format - can capture as ProRes 422
-PANASONIC - betting big on AVC Intra, ProRes 422 is an "outstanding post-production format for Panasonic's new genration of AVC-Intra based camcorders"
-RED (FIRST TIME THERE'S APPLAUSE) - VIDEO
Red Video
-edit 4K w/ease & elegance
-2 ways to work w/4K files in FCP
-native Redcode for DI finishes
-ProRes for broadcast work
-can plug 4K footage, plug into laptop, convert to ProRes 422 (!!!!)
-CineAlta cameras - MacBook Pro running Final Cut, how to get F900 into
-NEW HARDWARE - AJA device to get HD-SDI into FW800
-looks like a little G5 w/a handle on it, crapload of ports on the backside
-"I/O HD" hardware
-has ProResHD codec IN THE HARDWARE can move 10b422 ProRes - SD/HD up/down/cross conversion all in hardware
-10"x12"x15" or so guesstimated size based on seeing it
-PRICE? introduced at $3495, available in July
-exciting to work with upstarts like Red, AJA
OPEN FORMAT TIMELINE:
-mis formats
-mis resolutions
-mix framerates
-5 minutes after using it, you stop worry, IT JUST WORKS
-Smoothcam - remove unwanted camera motion right in FCP
-background optical flow analysis
-adjust parameters
EDITABLE MOTION TEMPLATES:
-access Motion templates directly w/in FCP
-can access templates in timeline in fCP
-can change instances to edit the master - IS LIKE STYLE SHEETS
-Motion is more integrated, and is a part of, Final Cut Pro
DEMO:
-Open format timeline, Paul demoing
-drag a file to timeline, FCP can set timeline to match
-22 MB/sec for 1080p24 4:2:2 ProRes
-if you drag a DVCPRO HD to timeline that is 1920x1080, it'll scale and aspect ratio correct on the fly to make it right
-mixing uncompressed w/ProRes to DVCPRO with a realtime effect, UNCOMPRESSED 10 BIT with realtime effects
-have interlaced DV footage, drop on timeline that is progressive, it just figures it all out
-could always send video to Motion, now can bring graphics to you - add templates from Motion are in FCP, can Superimpose, Overwrite, or Insert
-opens in Viewer to edit the text in FCP
-(has an orange render bar)
-unrendered Motion Template over 10b uncompressed video, plays...but w/low frame rate
-when change a template, ripples through EVERYWHERE you used that template - style sheets!
-FXPlug stuff - drop a plugin onto timeline, GPU realtime stuff
-plays back in pretty damn real time
-ProRes vs. Uncompressed video (using DCI StEM footage) - has split screen, plas it fullscreen
-the sample they are showing us, that I don't see a difference in, is TENTH generation - they've encoded and reincoded
back to Paul Saccone
MOTION -
embracing 3D
-multiple cameras and light sources
-intuitive navigation
-adding paint
vector based paint- particles, pics, etc.
-pressuure pen, speed sensitive
-edit strokes in 3D space
-apply behaviors to strokes
MATCH MOVING
-simple now
-autmatically follows the path of any animated object
-suggests points and inltelligently creates motion paths for video
-associate a path to an object, it handles it
-track, match, move on
RETIMING:
-retiming w/out keyframing
-hold frame, set speed and other creative timing effects
-slip and slide retiming effects
-isn't tied to the piece you started with, can apply behavior elsewhere
AUDIO BEHAVIORS;
-aimations respond to the soundtrack
-control animations based on volume and frequency (After Effects already did some of this years ago, but was work)
-assign to any parameter on any object
DEMO OF THE NEW MOTION:
content library in Motion - tons of new stuff
-animated lines & widgets and stuf
-can animate the details of those library things to find the track you want it to effect, set scale to amplify it
-no copying of keyframing, is just a behavior
-tracking - new behaviors for tracking behaviors
-tracking points gives a 4x zoom, just shows the zoom
-hold down option and it shows you good tracking points WOWOWWOWOWOWOOWW
-Motion analyzes and figures out color space and subsampling etc. FOR YOU
-can also track in 3D space, does cool 3D parallax thing
-true 3D stuff in Motion:
-can move "observer" camera of scene w/out altering the shooting cameras
-while working in perspective view, get a live feedback of the camera's view
-there's sweep and dolly behaviors for cameras that do those move for you
-all behaviors have a little text description as well
-cameras can have targets to watch "scenes" that you set up
-as a former 3D guy, this is SOOOOOOOO much easier - isolate the movements by type not just axis
-Motion's new paint tool to add a "swoosh" around the text
-can create a paint stroke from anything, as well as their existing large library
-a lighting effect can be a brush
-can alter every attribute
-can edit the path of the stroke to move the stroke through 3D space
-can click a "make particles" based on a glowy bit
-have full controls of particle system
-but can click the "3D" button for particles to make them 3D (coooool, and applause)
-can alter the size of the emitter - be a point or even a box
-IMPRESSIVE realtime performance!
AUDIO:
SOUNDTRACK PRO - marriange between picture and audio
-3-up video HUD for placing clips (of audio)
-precisely align
Advanced Take Management for dialog replacement
-bring in multiple tracks and composite multiple track out of portions that work for you, take the composite down the road, and be able to dive back in and change the settings of that comosite
-surround sound embraced at core
-surround mixing
-single project for 5.1 an dstereo
-intuitive panner w/automation
surround sound plugins
-library of over 1000 music tracks and sound effects in 5.1
-good panning tools for speaker to speaker controlled by mouse in realtime as you do it
CONFORM:
-sync changes between picture and sound
-see diffferences highlighted in the grpahical view
audition, then accept or override changes
-if the edit changes for picture, can go through changes to accept or reject, or just let it work to move all the stuff where it is supposed to go
Soundtrack Pro 2 Demo
common to make fades in audio
-just drag corners
-drag clips over each other to do cross fade
-to detail crossfades, double click and you have a fade selectior HUD
-linear/log/s-curves/etc.
-location dialog - lots of potential problems
-showing a base thump in a clip (bumped microphone)
-waveform editor for any clip
-hit tilde key and get tool you need under mouse cursor (nice!)
-can scrub and find the problem
-have a frequency spectrum view
-can see brights for amplitude and frequencies
-can draw a box around an area in frequency spectrum view to edit just that part
-and it fixes the thump REALLY well
-and it is all non-destructive, so is all editable
-if there's a bad clip from set, they have 3 ADR options to try to fix it
-they can do a multi-clip take
-can take the 3 editors into multi-take editor to find which one works better
-can create a composition that will fix it
-with the take editor, can cut into the phrases and drag around and do fades to find which portion of which take you want to use....and all the bits and pieces will remain with the clip - at any time can go back and fix, if goes into a different comp, that all comes along for the ride
after dialog, want sound effects
-ships w/over 2000 royalty free sound effects
-does a search for "door" to get a door slam sound
-traditionally is tough to sync, gotta add a marker on picture to target where I want it to go, there is a multi-point video HUD
-get a 3up view for before, after, and where the mouse is
-didn't catch how all that works, but looks very cool, quickie drag and do
-drag & drop it in, drag around, hold donw V-key, and it is done to sync an effect to the shot - yeah is FAST
(LIVE COMMENT FEEDBACK - THE I/O HD BOX IS $3495, WE DON'T HAVE PRICING ON FINAL CUT STUDIO 2 YET...dunno if you need other stuff for converting to ProRes - I/O HD does it in realtime, but how long does it take without? Dunno yet)
-he's doing audio stuff - the updated revised picture edit comes in, and get to see an overview w/changes
-conform audio to adapt to picture changes is quick and easy, w/overview view that makes it simple to see what's up and where things have changed, can review it to make sure it all correct before committing and finding out might be incorrect
-has many dish panners, double click and get a new HUD that is NICE - get a circle that oyu can drag source around in the circle, and it shows you what speakers those are getting mapped to
-can do it live in realtime too - so play it back, and move the audio source sound around
-cranks the LFE knob to make the fireworks hit be heavier
-can have surround and stereo mix in same project - can optionally use surround panners for the full project
-stereo mix lives separately from 5.1 mix, but stays all in sync (nice!)
-over 150 royalty free sourround mix music beds for temp tracks or final delivery
-over 1000 new surround sound effects
-when you pull in surround clips, all 6 channels come along for the ride with all channels along for the ride - is just ONE thing to drag around and control
-professional multi-track editing,
COMPRESSOR 3:
-is a major item now
-they use it inhouse to do all content for iTunes Store
-MPEG-2 broadcast streams
-iPod/AppleTV presets
-Telestream Episode Pro for VC-1, WMV, FLV, GXF, & MXF as a third party plugin to drop into place (big deal)
-timecoe overlays (!!!)
-audio and video fade in/out
-animated Motion watermorks (even unrendered Motion stuff)
-w/an 8 core station
-10 min HDV video to H.264 for iPod, takes 16:45 to do w/version 2
-compressor 3 talks to each thread on SAME BOX to 6:08 - 2.8X
-faster than realtime encoding
RICHARD TANNER talking about compressor 3
import a project as was done in FCP
-in compressor, can see markers from timeline
-new looking UI
-presets are better organized, defined by targets/presets for devices
-for the stuff you use over and over
-can create a custom folder with all your custom presets
-can drag it onto a clip to start the batch and applies all the presets
-can inspect settings as applied to a clip
-new features - can see source and change the settings for that clip
-16:9 content for iPod, for instance - can over-ride to make 4:3 if wished (stretched or cropped?)
-filters in Compressor are new
-Watermark & timecode generator
-timecode generator - can be either to start at zero or can pick up from original source clip (or from timeline for first option I take it)
-watermark - can "choose" a Motion project or a QT file
-doesn't even have to be pre-rendered
-a renderless pipeline between motion and compressor
-for the chapter markers in FCP timeline, can select one and open the edit window for it. HAve a # of devices on my list - can be relevant to all of them
-can give the chatper marker a name and URL or even an image - can be picked up from a file, or from a frame (for podcasts to pick the poster frame you want)
-iTunes will show the URL and the poster frame
-in System Prefs, can select # of instances (aka cores) to run 8 instances of Compressor to run one per core (this is in Qmaster settings)
-there's a badass core gauge that looks like %age utilization, and they swing up till all 8 processors get up to 95-100%
-in iTunes- chapter points all work with a pop-up, links that you typed in will take you out of iTunes to the web to the URL you set if you click in iTunes
-can publish to any device on the planet now
PRICING - IS STILL $1299 for Final Cut Studio 2
$499 upgrade from Final Cut Studio
$699 to upgrade from ANY version of Final Cut Pro
AVAILABLE NEXT MONTH
Back in 1999 in Final Cut Pro 1.0
-pro editing was $100K back then
Pro solution for color grading
-pro coloring is upwards of $100K
"SO not OK!"
-want to do for color grading what they've done for editing
simply called
COLOR
(this is where Final Touch went)
-realtime pro color grading for the FCP editor
-inherent all the goodies of FCP for color
-Coen Brothers have been FCP since 2003
-video of Coen Brothers talking aobut color
-color is an element you use in a film
-in Oh Brother, was first DI process
-only way to target what they wanted
-have done DI since then
-looks just like Final Touch - seeing footage
-the UI looks exactly like what I've seen before in Final Touch HD
-3D color viewer is new (some kind of 3D graph of color)
-(and that 3D think plays in realtime!)
-Send To Color is an option in FCP
logical task based workflow
-starts w/primaries, on to secondaries, then color FX, then geometry
-all same as final touch HD was
-3 way color corrector
-rgb & luma curves
-lfit/gamma gain
-3D scopes
-pull mattes based on crhoma, luma, and saturation
-custom chaped vignettes
-custom hue & sat
-up to 8 secondaries/shot
-ColorFX - over 40 effects to start
-exposure, film grain, vignette, alpha blend, noise reduciton
chain nodes together in any order
geometry - pan and scan, apsect ration conversions, zoom/pan/rotate
-can create looks that are saved & emailed
DAVID GROSS DEMOING:
-music video working on
-got an edit in FCP
-go to file and use Send To Color
-shots drop in
-preview up in top corner, works on one screen (this is new from FTHD)
-working custom 1920x717 2.35 aspect
-have our 3 wheels as always, but now has curves below on same screen
-can make chnages to curves and get realtime feedback on screen
-secondaries room, have 8 tabs for 8 secondaries - have 9 ways to fiddle w/image
-he wants to drop a grad in, but didn't shoot it (as was wise)
-so grabs vignette tool, defaults to circle, switches it to square, can drag around in UI to get it the way he wants it
-secondaries have inside and outside control for masks, so can give secondary #1 look A inside and look B outside the selection
-so really 17 total adjustable color things - if you can't do it there, you've kinda blown it
-MY BIG QUESTION - REALTIME OUT HD-SDI?
-another shot - has grainy shot
-has an auto-balance tool (think Photoshop)
-can do sat curves - saturation control on a curve, add markers to a curve
-can do secondary color corrections - to suck the blue out
-can drag and drop grades between shots
-to play with color on his shirt, can go to preview tab and key the shot, got a 3D scope - all the pixels in 3D space, like an MRI for the picture
-can zoom in on it
-like a lamp-post - whites at the top, shadows at the bottom, and colors in a ring around
-a good way to learn how to read color
-can see the blues of his shirt in the scope
-can "paint" your key (like FTHD did), but dragging the eyedropper along, see the matte appear - drag it over different colors to add'em to key
-then have a "cage" around the pixels in the 3D scope, can edit in the 3D scope to isolate
-but it changed his hair, so added a vignette to isolate and soften, so only does shirt not hair
-another shot - geometry room - can pan & scan and rotate
-drag & dropped a look from another shot, made a secondary, made a vignette, so adds a b-spline custom shape
-can light more flatly as you shoot, can then tweak more in post - can soften the shape differently inside than out
-can even edit the b-splines of the sottness inside and out - drew one spline for the shape, added softness, THEN that made new splines for inside out, and THOSE can be edited on a point by point basis (and perhaps keyframed?)
-ColorFX room - bleach bypass, etc.
-(Graeme's plugins from before for FTHD - should work here too?)
-saved looks that are node trees in Final Touch
-can drag those looks of node chains to other shots in bulk or onesy twosey
-showing before/after - major differences
-they aren't demoing exactly how it gets back, but I assume it is MUCH easier than it used to be - still have to render all your shots
-questions in my mind - realtime preview runs where? Where do we see it? Can run through BMD or AJA card in realtime for 1080p24? Can we run it through the AJA I/O box?
-SD, HD & 2K grading
-primary & secondaries, custom curves, scopes, 8 secondaries, saveable looks, naturla extension of Final Cut
-PRICE - gotta make it accessible to everyone
-IS INCLUDED IN FINAL CUT STUDIO 2
-huge applause from audience
Thanks for the detailed post. The guys at MacRumour apparently couldn't cut it from a technical standpoint and gave up. So their big post from the event turned out to be mostly useless.
I'm interested to see the mixed formats on the same timeline feature. I'd like to give that a test drive and see what happens. Going to be some interesting articles from the initial benchmark and the like tests (hopefully very soon).
cheers.
I got this from HDforIndies curties of THE awesome Mike Curtis. His blog is the shizzle mah nizzle.
I think he had a heartattack when they announced the REDCODE support.
Omg.... this is so awesome. I can't believe how much motion just got better. I honestly LOVE Motion to death, I use it daily and I'm so happy it got an upgrade man.
What an asshole. Learn to read. Just kidding, marlon. But really... read.
Man go to the apple site! THe Motion 3 demo makes my eyes water. FINALLY it's getting the attention it deserves man. Check out that 3D work space. GAHD.
Hey, anyone else notice Jarred in the RED quicktime in the apple FCS area? I think that's him fitting a matte box onto the camera.
awesome FCS update btw.
dmc
dmc
LOL yeah that was Jarred. Hilarious.
This is just amazing. They were editing 4k right on the Mac man. Wtf. Then hit that new Apple 4:2:2 codec.
I want it NOW.
It's tough to imagine that everyone using the product wouldn't update - it's a no brainer!
Although according to Apple they have 800k (paid) users of Final Cut Pro - it might take a while to get in hand.
That would represent almost 400 million dollars for Apple - a nice chunk of change for an upgrade.
dmc
It was your avatar that gave you away. :)
I know on some Apple products if you purchased within 30 days you can get the new version pretty cheap. Not sure about FCS2 though.
I didn't even finish all the new features and I placed my order. :)
