Levitation of a little girl
Shepi
Hi,
I´m currently working on a low-low-budget movie in which a girl is supposed to levitate above her bed. Most of the shots will be CUs and MCUs but there needs to be at least one wideshot in which she is clearly seen.
I was thinking about two ways - greenscreen directly on the set/ wirework. Personally, I prefer wires because it will look much better.
Anyway, I wanted to find out if anyone has any experince with something similar. What would you prefer?
Thanks guys!
I suggest using on set wirework if you have the expertise. You'll get a much prettier effect and save yourself a lot of time and post work making it look good.
That said, if you don't have the expertise and proper equipment to do the effect, use a green screen. Even basic wirework can be dangerous if done incorrectly or with substandard equipment.
Jason Hilton
http://www.tumblemonster.com/
Wirework with green screen. Make sure that you use greenscreen tape on the wires themselves so they are easily removed. You will need a specific harness for the deal though. You can rent them, although maybe not in the Czech Republic.
