Flipping M2 upside down footage
robot909
oops gotta flip it to read...
Is there any quick way or a "button" to flip clips 180º ?
I'm tired of going through dozens of clips and flipping them...
thanks!
Set rotation to 180 on one clip, then copy it. Then paste attributes to all others in the sequence.
Naoh
You can't flip them in the bin...
That being said, it would be nice if someone could develop a "batch" process that would flip all your footage. It would proabably take a long time, but you could set it going before you left for the night.
It's possible that Compressor could be worked out to do something like this and then apply it to a whole folder of files.
I will give a big virtual handshake to the first persone who can figure that one out.
Well one way you could do it would be to select all your clips in the bin, drag them into a sequence, paste attributes then drag them back into another bin. That should do the trick...
Noah
you can add effects to clips in the bin. nothing has to be in the timeline to add an effect. I have a preset effect in my faves and just paste that into all M2 clips in the bing before i drag to timeline
Hi Cynic821,
So we are not loosing any resolution. The way to go is in motion rotation 180°, isn't it.
Correction : I just did a new test and Filter Flop (both) seem the way (no lost of resolution) to go compare with Motion rotation 180°
Thanks for your quick answer.
ya shadow. Flop with both is what i use, its a favorite in my Bin and i just drag it onto the clips , no res loss, and on core 2 duos i can apply that, a color correction and 1 other filter and still dont have to render for full res playback! w00t
There was a small XML tool made to auto rotate all media in a project - if you have hundreds or thousands of clips its the way to go as its easy and super fast:
rotateClips
