Rylan Zolinski
Or can I get a long cord for the mic and still be able to use the boom pole and mic? If it's not a good idea, how much is a basic mixer? I know nothing about mixers...
timapter said:to be clear, if you have a dvx you dont HAVE to have a mixer, you can plug straight in with almost any microphone (the exception being T powered microphones).
A mixer is a great thing to have, though.
yo mattin, can you or anybody else give me a coupla hypothetical situations where i would need a mixer on a short film? or when it would best to use a mixer versus just 'figuring it out' with one mic?
FilmBoy77 said:yea, the cord from my mic is 25ft and connects from the mic, wraps around the boom and plugs into the camera and i still have several feet left over for the boom op to move around without stumbling over me.
Then I think you may have a bit of a problem using external mixers with your camera. If memory serves, the XL2 (like the XL1 before it) will not accept line level audio input when shooting. In other words, even with an XLR adapter, the incoming audio will have to be mic level. If the mixer in question will output a mic-level signal (my PSC M4 mkII will do this), then you can simply take a mic-level output from the mixer into the camera's mic inputs (switching off the camera's phantom power of course). If your mixer lacks that feature, you'll have to place a line-to-mic-level attenuator between the mixer and the camera. Otherwise, the incoming audio will be hopelessly distorted.Morox said:By the way, I use an XL2, not a DVX.
SMuir said:Then I think you may have a bit of a problem using external mixers with your camera. If memory serves, the XL2 (like the XL1 before it) will not accept line level audio input when shooting. In other words, even with an XLR adapter, the incoming audio will have to be mic level. If the mixer in question will output a mic-level signal (my PSC M4 mkII will do this), then you can simply take a mic-level output from the mixer into the camera's mic inputs (switching off the camera's phantom power of course). If your mixer lacks that feature, you'll have to place a line-to-mic-level attenuator between the mixer and the camera. Otherwise, the incoming audio will be hopelessly distorted.
Of course, I may be mistaken about the "mic level only" limitation on the XL2. The last few times I've mixed for shows shot with Cannon cameras, I've just recorded double system onto a Fostex FR-2.
XLR line in?Morox said:The XL2 doesn't need an adapter. It already has two built in XLR ports. EVERYTHING is changed on the XL2 from the XL1, except for the mic.
SMuir said:XLR line in?
