mvb
DVXuser Sponsor
Barry_Green said:Vegas 6.0, using Raylight for the HVX files. Imported the files directly into the timeline, set on best/full, exported as a still from the timeline. Brought into PhotoShop and resized to 1920x1080.
For the record Raylight does smooth the chroma but many Mpeg2 decoders (in Vegas is it MainConcept?) do not, since, if the images are likely going back to tape or to an HD monitor, there's no need.
Smoothing 4:2:0 color for a still image is tricky, it actually takes 4 fields to do it correctly. If the decoder doesn't do it it can be tough or impossible to do it later esp. after a conversion to RGB and 24P.
Another thing to consider is that when a color-saturated image goes through compression, there are more bits required to compress the image vs. the same image with undersaturated colors. meaning that for a constant bit rate, the less saturated image may look more lightly compressed and sharper.
