hvx_germanboy
Ok, i got a editing PC with an SP card and Edius Broadcast 4.1, so all codecs should be installed...
1st Problem: i did encode Canopus HQ clips(not lossless) from 720pn(pal) footage and AE(v.6.5) is not able to read it(error message: reading from video streak..bla bla..sorry, this one is in german, dont know what it would say exactly in english..!).
2nd: AE does import fine when i encode the clips in Edius efore to Canopus lossless, first thing here is: if i open it in AE it says that there are 50 frames(judges it as that and sets the same when i try to export from AE)
-when i have finished post-work in AE, i cant encode to Canopus HQ, unless it is Canopus lossless.....that works, but i see that the quality is much less(mostly the sharpness of HD is gone when i reopen it in Edius...!) then the Canopus clips i re-encoded from the .mxf-files in Edius before...so is this due to AE, or just due to the fact that this is going to the next level of compression?(actually it shouldnt as it is Lossless...well at least not too much..!?)
I could post frames too..i am really curious to know wat happens here at the different points, maybe i should get AE 7.0 and see if this solves the problem as there are some other bugs occuring in AE too..( AE crashes while rendering when try to switch to a different window or program....)
:dankk2:
