bayarea_dvxer
[perhaps this needs to move to a different forum? I'm not sure if this is an issue with DVX100a, FCP, Compressor, DVDSP.]
I'm having a problem making a high quality, sharp 24p DVD from my 24Pa squeeze mode video for a 45-minute documentary project. The DVD looks sharp on a 16 inch, 600 line resolution production monitor. Shots appear to be well in focus.
But, when I view the DVD on widescreen tv's (50+ inch) it's blurry. Soft focus, some pixillation. The same thing, of course, happens when I blow up the MPEG-2 files. They are sharp at actual size (720x480), but ugly at Double Size. I realize it's hard to blow something up when there's no extra data there to help. But, in the past I've made 60i projects that looked much sharper on the big tvs. The big tv's seem to do a better job blowing up my 4:3 60i material compared to the Squeeze mode material.
I realize I'm not using a $50k+ camera, or even the HVX200 but my expectations for the DVX100 were higher than this. Perhaps there's something I'm doing wrong?
My workflow:
DVX-100a camera shooting 24PA, Squeeze Mode, F6 Scene dial.
Detail Level 3, Master Pd -5, Gamma Cine-Like_D, Matrix Cine-Like, Skin Tone DTL off, V Detail, Thin
Capture into FCP 5.1.3 with DV NTSC Advanced 2:3:3:2 Pulldown at 29.97 Anamorphic
Edit on DV NTSC 23.98 Anamorphic timeline
Then, I've tried both
A) export timeline as Quicktime movie, current settings, Don't check recompress all frames and don't check make movie self-contained. Select the 'high-quality' checkbox and save (not sure if this is necessary for making the dvd or only affects computer preview). Then to compressor and export to mpeg2.
B) export directly to mpeg2 using Compressor from within FCP.
In Compressor 2, i've read 1-pass can be better than 2-pass and bettter motion sometimes better than best.
I've tried the following Compressor presets:
1. DVD: Best Quality 90 minutes 16:9 (uses 6.2 Mbps 2-pass, best motion)
2. Default MPEG-2 60min High Quality Encode Widescreen (uses 6.8Mbps, 2-Pass VBR, best motion)
3. My own Custom setting: 7.5Mbps 1-pass, better motion estimation
The resulting DVD (widescreen option selected in the track) looks sharp on the 16" 16x9 production monitor.
But slow focus and blurry on bigger sets.
More options:
1. I've tried exporting the sequence as TIFs and using PhotoZoom Pro 2, S-Spline XL and regular S-Spline (with unsharp masking and without.. but tons of options here), to save as original size (720x480) and then import image sequence back to FCP. I haven't tried Uprezzing to HD with PhotoZoom (not sure which HD to use) and I'm not sure how bumping it up AND then back down to 720x480 for DVD would improve things. I see many (most) DV projects get bumped to HD for digital projection/film out, but would like really help for a DVD and what workflow/format to use?
2. I've tried unsharp mask and sharpen filters in FCP. I can't get a noticeable improvement.
3. Other MPEG2 compressor? Squeeze? Hardware encoder?
4. Buy a native 16:9 camera (HVX200) and reshoot in HD.
My workflow:
More options:
