I am trying to capture some video shot on MiniDV tapes through my HVX200. The video was shot in a DVX100 in 16:9 and 30P fps. I have selected the following presets:
Sequence preset = DV NTSC 48kHz
Capture preset = DV NTSC 48kHz
Device Control preset = FireWire NTSC
I have my batch capture log ready to import, but I test one clip first just to make sure, and it's not working right. I've even gone as far as capturing additional clips to make sure. The clips import automatically as NTSC - CCIR 60 for the pixel aspect and anamorphic in the bin. These shouldn't be anamorphic though because the DVX100 is not anamorphic. I can uncheck the anamorphic in the bin, bit then in the viewer "Show As Sq. Pixels" option is automatically selected for every clip. The same option is selected automatically for every sequence if I create a new sequence. This causes the image to be stretched vertically so everyone looks skinny and their faces long.
If I uncheck the "Show As Sq. Pixels" option in the viewer and in the canvas the images look normal. I have uncheck "Show As Sq. Pixels for every clip I capture. If I open those clips in Quicktime they are all squeezed vertically so everyone looks fat or stretched out horizontally. Looking at the properties in Quicktime they have the "Conform aperture to 'Clean'" option turned on in the Presentation tab. Unchecking the conform option makes the clip open correctly. I can change all this for all clips manually if I have to, but it would be a PITA and doesn't make sense. Doing that also causes me to get a gray bar on the top and bottom in both the viewer and the canvas and I can't get rid of them. Selecting Window/Arrange/Standard or any other arrangements does nothing. If I manually adjust the windows and try to arrange I get the gray bars again.
If I change the sequence to anamorphic the gray bars on the top and bottom go away, but then I get gray bars on the sides and can't get them to go away.
I somehow have also managed to get the canvas to give me black bars on the top and bottom instead of gray, but there's gray lines outlining the actual frame of the video (image with the black letterbox bars the DVX100 put there). I don't know how I managed that with the settings the same as in the default DV NTSC sequence preset I've been using. It has the "Show As Sq. Pixels" selected and if I deselect that option I get the gray bars again but the image is stretched horizontally. Also, if I change the sequence settings for Pixel Aspect Ratio from NTSC-CCIR 601/DV(720x480) to Square the image looks right but I have the gray bars at the top and bottom again and they won't go away.
The sequence is never requiring me to render.
I'm using FCP 5.1.4 on a G5.
What am I doing wrong?
