Can Scanner
I'm doing some compositing in AE 6.5 Pro with Keylight, and when I frame-advance or render/export, it flickers; every other frame or so is the original greenscreen clip as though Keylight were never applied.
Here's how I have my composition set up:
I'm making the bed of a truck look really big.
I have a shot of the bed. (I put the camera in the bed and shot straight out of the back of the truck, with the bed door down.)
On top of this, I have a greenscreen shot of two people.
I've applied Keylight to the greenscreen shot, and then scaled it down so the people appear very small, peeking over and looking into the truck bed.
But only half of this composition is good- every other frame or so simply shows the original full-size greenscreen shot (prior to applying Keylight and scaling), with no sign of the truck bed shot, and with the SCALED-DOWN greenscreen shot ON TOP! It looks like a flickering mess!
I'm using 720p 24p footage from the Panasonic HVX200 that has been converted with CineForm Aspect HD with the CineForm intermediate codec (which I've used plenty of times without error.)
Composition is 23.976 fps, and the clips are 23.98. (Again, I've used these settings before and they worked fine!)
Is there some tiny setting I'm overlooking?
Thanks in advance!
EDIT: I've been working with some new compositions with different effects (masks, luma keys, rotation, scale, etc), with up to three layers. It seems to be shifting the effects among different layers, every other frame. It's a complete mess. This is really weird.
Thanks in advance!
