slinks
so, I saw some ghetto flouro ring lights before in the past but i thought of super simple way to do it. Anyone should be able to do this.
well anyways here is a screen grab of a test i did @ F6.8, wide open, ped set to -7 and I'm using the preset 3200k white balance preset. No other lights used besides the ring light.
what you need is your dvx, a flouro circline bulb, a ballast, zipties,and a plug or whatever u call em.
I got everything from homedepot except for the ballast which I got at sunpark.
this is the ballast. model # LC12014T
http://www.sunpkco.com/catalog/product_info.php?products_id=700
and here are the specs on the circline flouro light which has a color temp of 4100k. model # FC12T9
http://www.bulbs.com/eSpec.aspx?ID=11492
here is a look of it all put together.
From the picture you should be able to figure out how I secured the ringlight to the default dvx hood. Its that simple.
the only tool u would need is a screwdriver so you can tighten the plug onto the wires of the ballast.
this plug...u can probably find everything here at homedepot or lowes but the ballast u may have to order online or look for a light store. just make sure the ballast is meant for a 4 pin 32 watt circline light.
http://images.lowes.com/product/converted/032664/032664539404md.jpg
hope i was clear on everything here. let me know if you have any questions.
enjoy!
As Tommy L. says, "If I can do it, you can too!"
I will evenutally build it so the ballast can be attached onto the dvx shoe mount.
Just need to find a small plastic case i can put the ballast in. any ideas?
enjoy!
