Running into a bit of an issue that some of you may be able help with:
I have been capturing several tapes that were shot in 24p - I captured 29.97 then reversed the telecine in Cinema Tools to conform/relink 23.98 files. Everything was going smoothly - then - I stuck in my final tape / captured and when I tried to batch reverse telecine in Cinema tools (like I had previously done) - a different window popped up asking me what the files were captured as : "Field 1 Only, Field 2 only, F1-F2, F2-F1" Why is it asking for that option on this tape and not the others? Is it possible that the DP shot this tape on 24PA vs. 24P? I thought that this may be the case, but when I re-captured in FCP using 29.97 "remove 2332 pulldown" - my clip did not end up being 23.98 and I could still see the interlaced frames.....
Any ideas???? Your help is greatly appeciated.
Thanks in advance!
Mike
Thanks in advance!
Mike
