FCP 5.1.3 available
fixed render files to be compatible across both intel and power pc systems, good if using multiple computers to edit the same project.
daylight savings time compliant fix to go along with that update and added keyboard commands
ok found something on creativecow
http://forums.creativecow.net/readpost/8/924481?pview=t
and
http://manuals.info.apple.com/en/Final_Cut_Pro_5.0_lbn_z.pdf
Late-Breaking News About Final Cut Pro 5.1.3
Final Cut Pro 5.1.3 is a maintenance release that resolves performance and other issues.
Render File Compatibility
Render files created on both PowerPC-based and Intel-based Macintosh computers now work properly on either type of computer.
Keyboard Layout Issues Resolved
Final Cut Pro 5.1.3 adds several commands to the default keyboard layout that were missing in the previous version.
Issues with Cross Dissolves in Nested Sequences Resolved
Final Cut Pro 5.1.3 resolves cases in which cross dissolves did not work as expected in nested sequences containing still images with adjusted motion parameters.
True, P2 import bug yet to be resolved.
Shane (and others)...
Might be worth trying to import identical problematic files into FCP 5.1.3. I noticed in the update process that the updater replaced the DVCPRO HD component (which is a QT component). Perhaps (and I say perhaps lest I start an internet rumor that spreads around the globe in nanoseconds) there is an undocumented fix for the P2 problem. Apple never acknowledged the problem formally in 5.1.2
Ned Soltz
It says on the software update that it does something with P2 import.
I'll test later today.
Gunleik
1st up, I'd like to personally hear from anyone who does the 5.1.3 update and still have FCP claiming files are corrupt that P2 Log can import.
2nd up, here's Apple's Official word on it, not mention of anything related to P2 or DVCPRO-HD. Although I see the update does add to the system a package (reciept) for a DVCPROHDcomponent file. Let's hope that does the trick. Here's Apple's official:
The update document that the auto-update links to says something about P2 import, but it is under the 5.1.2 section.
Hey BenB, I thought you swore off the HVX? Is there a change of heart we should know about, or are you just waiting for something better?
Sorry Ned...same files come up corrupt.
Found out that the camera's firmware is 1.03...gonna update to 2.03 when I get a chance and see what that does.
It'll be a couple days.
I never swore off the HVX.
Just found out that Conduit is broken in 5.1.3, too.
