Dreamy Look
Joe_Hicks
I'm finishing up a dream sequence in which the talent begins to daydream. I want his image to begin to ripple and fade out and go into the dream scene. I've tried using the ripple effect in Premiere Pro 2.0 and key framed it so the effect gradually becomes more and more intense. But when I apply the keyframes it isn't a smooth build up, but somewhat stairsteps it's way from one intensity level to the next. (The footage is 30p)
Anyone have a better way to achieve what I'm attempting here?
Thanks,
Joe
Yeah, I tried the bezier keyframes, but no luck. I'll go ahead and see what I can do in After Effects. I'm not too impressed with Premiere's attempt at this effect.
Thanks!
Try to keep the number of keyframes at a minimum and let the curve do the work.
I've not had much experience with Premier but Affter Effects is adjustable in the turn down controls.
You could trying slowing down the footage you want the effect applied to at half speed or slower, apply the effect to the whole slowed down footage. This might make the keframing changes more gradual, then export that as a video file, re-import and then speed it back up to original speed.
Jeremy-
Great idea, but... I tried that. Footage was shot at 30fps at 1/120 shutter intentionally to get the best slow-mo at 50%. Still jumped all over the place. It lacks smoothness at 100% or 50%, doesn't make a difference.
Thanks though-
Well, After Effects took care of it. Ripple Effect was all I needed and it was very smooth. As well, I added a diminishing gaussian blur-- looks great.
Joe, the problem is that in Premiere some of the Effects sliders don't handle decimal values, so even when you keyframe, it jumps from 1 to 2 to 3 and so on, and doesn't do any inbetween 1.2 1.4 1.6, etc., if that makes any sense. Just big jumps. Most everything in AE will accept decimals, which means it will do smooth ramped keyframes.
