ChuckS
When starting a new project, I set the preferences to HDV 1080i 29.97. When I inport HDV footage its widescreen and plays great in the preview window but as soon as I plave the clip in the timeline it appears to be playing it back in 4x3 and zoomed in. I can't change the zoom on the record monitor (its greyed out).
I have checked the project settings, in the general project settings the editing mode is greyed out and I can't adjust it. If I press the playback settings button I get the HDV Playback Settings GUI with Enable YUV checked, Use DirectX Enable External Monitor unchecked and Save Transcode File Checked
In the Frame Size it is 1440H 1080V but they are greyed out and I can't adjust them. The rest is normal stuff. In the Capture Preferences HDV is chosen (It captured without any problems and no where to adjust resolution so I guess it captured correctly)
In the Video Rendering GUI Compressor is CineForm HDV 1080i 29.97. If I click on the configure tab I get the HDV Compiler Settings which just has a button that if you click on it you get the option to upgrade the CineForm Codec, there are no adjustments to make.
I can't find any other setting that might be causing this. :huh: In the info tab of the clips the resolution is 1440x180(1.333) which is correct for HDV. Any suggestions or thoughts where I might find some help would be appreciated. :engel017:
