so any super 8 film will work? that's what i was confused about?
also, will basically any super 8 projector work with this film?
i know, im just getting into real film
so wait. i'm thinking of just projecting onto my projector screen, and then recording with my dvc30. if i have negative film, film something, record with my dvc, capture it, what will it look like? inverted?
also, do i have to go through a whole roll before i can watch it on a projector, or can i record a bit, watch it, the record more, etc.
thanks alot
ohhh shnizz thanks alot, i didnt know you had to process, my bad.
anywhere you know does it?
Can you clear me up on the processing...uh...process?
Specifically, what is the difference between processing and making a light print? Does just processing make a roll that can be telecined?
Robert86 said:Processing the film is what you need to do in order to get a negative(negative film) or positive(reversal film) from the latent image on the film when shot. Just like when you shoot 35mm still pictures with the family or whatever, when you get it processed, it's the same uh...process. A (work)print, whether one light or best light is generally for offline editing.
Just remember that you need to have your film processed in order to see any kind of image. The you could either make a work print or telecine thereafter.
