Jarek Zabczynski
Brevis is awesome.
dogmeat said:I was wondering about the lenses that work with the Brevis...if going with the Canon FD lenses would I get a vignette on the 85mm or tighter? Is there no point in getting anything on the long end? Every great shot I see is with the 50mm at 1.4...I also wonder what the 17mm looks like:huh:
I've posted some vid in the thread below using Canon 85 and 50mm lenses on a Brevis with the HVX...in low light. You'll see that the lenses wotk great with the Brevis.was wondering about the lenses that work with the Brevis...if going with the Canon FD lenses would I get a vignette on the 85mm or tighter? Is there no point in getting anything on the long end? Every great shot I see is with the 50mm at 1.4...I also wonder what the 17mm looks like
guskersthecat said:Eu, so far I haven't encountered a flyer user on HVX with the Brevis. There are a few folks who have asked similar questions at the cinevate forum and will soon be shooting with their adapers.
Personally, I have not been able to get the Flyer's monitor to do a flip-flop of the image. It will flip it but not flop it. So you get a right side up image, but left=right and vice a versa...which can get pretty confusing some times. So I used an rig with a short Ultralight Control Systems arm to mount the monitor upside down. It works great.
Our rails will work now with just about anything and are designed to allow 60mm of height adjustment for the upcoming flip module,
Paul Nordin said:I have a Brevis adapter and use it with a Steadicam Flyer, and I love the setup. Shot a feature in Nov/Dec with that rig for several extended shots and didn't have any problems. The weight of the HVX with the Brevis/prime/Mattebox/FF/filters/etc is pretty much at the high-end of what the Flyer can handle. However, I've found that the Flyer is much happier (smoother) when it is loaded to near it's capacity anyhow. Of course the added complexity with the Brevis/Flyer is that unless you are stopped down (and I wouldn't stop down much more that T5.6 on the Brevis) you have to either really watch your camera/subject distance due to limited DOF, or use a wireless FF. And as someone else has said, a wireless FF required a skilled focus puller.
Have fun!
