Serious problems exporting HD PPro 2
buijon
I have a project I edited with mt2 files, some PS overlays, and thats it. I am trying to get it to export at the full resolution but preimere won`t let me. If i use DV it locks it to 720x480, i exported with the uncompressed microsoft uncompressed AVI with 10 bit YUV and windows media player 11 (just upgraded) still won`t play it, yet I can import it into premiere and AE and see the image fine.How can i export this project as avi so i can use sorenson squeeze to make all my different files types of it? (sorenson also will only 'see' the audio, no video avaliable) I double checked the project settings and sequence settings and they are set to 1440x1080.
How can i get sorenson squeeze and WMP to see the video? I`m going insane!
http://www.kiukle.com/temp/choices.jpg
Those are the choices that I have. Also when I export it, I have one clip zoomed in....when i export the zoomed clips borders are bigger than the rest of the video.....and all my transitions are messed up/misaligned.....what am i doing wrong? :(( I need this done by tomorrow. I can post a video if its helpful
__________________
Have you tried exporting using the Adobe Media Encoder? You can export a full size .m2t from there. It's under mpeg-2 hdv. Just check your setings so everything is maxed out. I think Sorenson can read these type of files.
Also, here's a tutorial by one of our members, shows you a great way to export from the Premiere timeline using a small free program...http://www.dvxuser.com/V6/showthread.php?t=85443
I'm not sure about the borders, I would just make sure your clips are all 1440x1080, with a 1.333 par. Maybe posting the video sample would help. Is your monitor window in Premiere set to "Fit", sometimes I forget to set it and realize I'm not viewing the full frame. Maybe the zoomed clips aren't zoomed enough.
-Kevin
thanks! your the first helpful reply over several boards, i`m going insane and angry trying to get it working. I need to show them for a pproval tomorrow. I hope you can take the time to download the zipped versions that demonstrate all the issues i`m having. Its a 50 meg zip, has an mpeg 1 version which now only has 1 mistake and its the very end where the tiff isn`t diplayed right, pieces of it vanish, its also a 1.33 par file made in photohop. Every other graphic was made in the same work flow. Then theres a QT version, you don`t need to be a rocket scientist to see all the crap its messing up...and i have no clue why! In the end the videos need to be converted to flv or swf for being hosted on a website. I want to use sorenson to make the flv/swf because it gives you much greater control over the compression. I`ll check out that link now and try at least exprting an m2t to see what i can do with it next. Is there a guide on what dimensions an flv file should be scaled down from the 1440x1080? Thanks for giving me light in this dark dark tunnel
http://www.kiukle.com/temp/taperoll.zip
*eidt* i have sorenson squeeze 4...doesn`t recognize m2t :((
I downloaded the files, I see the end graphic is messed up. It looks pixelated like it's been scaled up too much. Is it possible to create the graphic at a larger res? Or is that the only one?
One grip I have, the audio of the tape being applied comes in too quickly, I would apply a little ramp so it eases in a bit. Not to get off subject.
If you follow the tutorial from the link above you can export your flv from the timeline using Sorenson. I gotta run but I'll check back later.
-Kevin
Thanks for the extra input, its only a test video at the moment so i can learn all this stuff. It will be on the site eventually just so there is video, so i`ll definately touch that up ;)
I`m trying his method. tmpgenc isn`t free anymore (watermarks the video), but its looking like it may be more managable than premieres encoder. Its can`t do flv however. I did try premieres encoder for flv, the first video came out ok, the second one rendered corrupt. Any idea why that would happen? If i have to go the tmpg route (i`m testing uncompressed avi with it right now) i`ll have to still export through that then use sorenson to make the flv. Man why does this stuff have to be so complex. Thanks for the help so far, i hope i can have them done by tomorrows deadline....i`ll keep updating as things progress (or lack there of)
Have you tried the free debug mode frame server? I just installed it, selected that for my export file...it saved a small file that I opened with sorenson squeeze, and I exported a nice 720p h.264...all from the premiere timeline. No need to export then encode, it encodes from the original...very nice. No need for Tmp if you have Sorenson.
-Kevin
squeeze can open it too? Meaning i can 'link' squeeze to premiere and export the FLV from sorenson that way? That`ll be friggin sweet
*edit*
I tried it. I exported with the framework from premiere 1440x1080 1.33par, and loaded it in Sorenson. The first attempt it loaded in , and as i was making the flv, it froze at 20%. I tried again (after rebooting) and now it just freezes squeeze on import. Any ideas why? I would be a huge step if I can skip tmpgenc,
Also when i squeezed to flv from the Uncompressed AVI, i`m not sure why but it always came out stretched horizontally. Any idea if i should uncheck maintain aspect ratio? Or what dimensions i should type in for the fly (i want a medium viewable size for a website)
