Marshall monitor outputs
Xax
hi
i'd like to ask a small question to those who own a marshall HD monitor or if someone tested this in particular...
i want to use the marshall monitor since i will probably get myself a m2 with a flipped image... so if i use the component in, and then component out again to another monitor for the director, will the image be flipped as well?
thanks for the answers in advance, i know that somebody mustve tested this :)
Yes the image will be inverted going through component out. Best way is to mount an LCD to a C stand. Vesa mount with 5/8 inch spud.
Image will be inverted. Although I've never done this with my Marshall, it is possible to mount that monitor upside down, using the existing mounting plate there are screw holes on top of the monitor. For that output at least you can view the image flipped back to proper orientation!
Streamliner is correct. Just mount the Marshall upside down and then the outputs will be normal. It's easy to switch the mounting orientation.
