MovieSwede
I have tested a couple of different methods to achive 23,976P from 25P source.
First of all it seems harder to go 25P-23,976 direct due to you can only change speed 1,000 0,999 0,998 etc.
So if I first makes a 25P-24P conversion (0,960) and after that render ill make a 24P-23,976 conversion (0,999)
But the question will be what method generates true 25P-23,976P
As i found 3 different take and not sure what will simulate and what really makes a perfect conversion.
1. Change time code of event? (25fps-24fps-23,976)
2. Change playback rate? (1,000-0,960-0,999)
3. Change undersample rate (1,000-0,960-0,999)
And then of course what would be the best of the 3 (smart/force/disable).
Done some test but would be nice to discuss the theory.
