Hello all, I have a DVX100A cam and use Sony Vegas to capture and edit. Ive tried everything in the properties section. Ive tried to blend the fields, interpolate the fields, i left it on none, nothing is working! I shot my footage on 24P mode and in the properties section i have the correct template (NTSC DV 24p (720x480, 23.976 fps). I have the field order correct but tried them all, progressive scan, lower field, upper field, everything. and no matter what, after i render the clip it always turns out being interlace. Now i read that Virtual Dub deinterlaces but when I use Virtual Dub my video comes out stuttering a lot.. on that program i really dont use the settings much other then to deinterlace. So should I use a certain option on virtual dub to get my video playing perfectly, or is there something i can do on vegas to properly deinterlace my footage, or is there anything that i can do to correct this problem.. any advice will be greatly appreciated
