FCP + MAC PRO + 2DRIVES = 2DVD's BURNING TOGETHER??
Holy Harry
I've just been asked to burn 35 copies of a short demo I've made. I'm using a new Mac Pro with two 16x double-layer SuperDrives. I know I can't burn using both drives directly from DVD SP4, but can anyone suggest some kind of way to utilise them both and save time burning 35 DVD-5's?
Much obliged!
Can't you use two separate applications, like DVD SP4 and something like Toast or Popcorn? Use SP4 to burn a VIDEO_TS file and then use Toast or Popcorn to burn that copy while burning another copy through SP4.
you could export out of DVDSP an .iso file of the disc and burn that with one drive using Disk Utility while you burn with the 2nd drive in DVDSP.
Using toast you can actually burn a DVD for each instance of toast on your computer. Just copy it to different folders. The instances will open as discreet applications.
Dragon Burn, which I love, can burn to multiple DVD burners at once on your Mac. I do it all the time. And it's a lot cheaper than Toast!
