gonzoish79
Can someone kindly give a walk through on the MXF into the editing system. I've tried everything that I can think of and I can get them into editing system. I have them saved onto a hard drive.
I recommend against doing that, as it will often lead to missing parts of the clip (video without audio, etc). But if all you're after is just that portion, it'll work fine.THoff said:You don't even have to use P2 Select (though that is the preferred method) -- you can even drag-and-drop the MXF file from Windows Explorer directly into the timeline or bin.
