stevemitchell
When batch capturing, after it captures the first clip i get an error box with the message "destination disk is too slow". I have the Maxtor 1TB external firewire HDD (Raid 1). Then stops capturing. Any ideas?
OK. I'm new to EDIUS. How do I change the drive? I checked the menus, manual, etc., but couldn't see where to specify the destination drive for capturing. ??bhiga said:That message doesn't always mean the storage itself is too slow, sometimes the system can just be too busy, or the datapath is clogged. Essentially it means it can't maintain the necessary throughput for the capture.
If your array is really RAID 1 (mirroring) and not RAID 0, 3 or 5 (striping only, striping with parity) then you won't get any performance benefit and it's acting like a single drive.
Try capturing to a different drive and see if you're more successful.
Brandon
