Review of the Letus35 Flip Enhanced
marco0782
Based on three months of owning a Letus35 Flip Enhanced:
Pros
- Great sharpness
- Great bokeh
- Flips the image
- To my understanding, it loses about as much light as the Redrock adapter
- Very easy to open up to clean
- Motor is virtually silent
- Sturdy construction
- I have yet to notice any aberrations or image distortions
- The price ($700)
- Shipping is extremely fast; it took 3 days to get mine
- Quyen offers excellent e-mail support
Cons
- Lots of dust inside the unit from manufacturing; even if you clean it dust will probably come back
- Several places for dust to stick (all the mirrors and glass elements); it's very time consuming and frustrating finding which mirror or glass element the dust you see resides on, then getting rid of it
- On my unit, a string of glue hangs down from the top (a manufacturing oversight) and I don't want to risk bending one of the mirrors to pull it off so I have to zoom in more than usual to hide the glue
- AA batteries only last 3-4 hours, but you can remedy this by using NiMh batteries which last much longer and can be recharged 1000 times
- If your batteries run out, you might have to point the adapter straight down after switching to new batteries if the motor doesn't turn on immediately (explained later)
The image quality is terrific and on par with the other adapters. You'd be hard pressed to prove to me or someone else that footage from any of the other adapters looks better, and what's amazing is that this one flips the image.
If not for the dust and glue problem, the Letus35 Flip Enhanced would be extremely easy to recommend. The thing about dust is that you may not know it's there until you capture your footage. The speck may be smaller than what can be shown on your LCD/viewfinder, and this is especially true on a high-def camera. I would recommend Letus owners to thoroughly inspect and clean their adapter, then shoot and capture some test footage to examine carefully. The first movie I shot had a speck show up when I captured and I was terrified. For the second movie I spent about two hours cleaning and inspecting the unit and the captured footage turned out fine. It was a standard-definition project, however, so I might have been less lucky with HD.
The light loss of between one and two stops is not a big concern if you have fast lenses and lighting equipment available. I've shot two movies with it so far and I didn't have any headaches compensating for light loss.
The vibrating motor is extremely quiet and does not pose a sound issue.
The battery life is only 3-4 hours with standard AA batteries. I would highly recommend investing in NiMh batteries which should last more than twice as long and can be recharged up to 1000 times. One *very* important thing to note is that it takes quite a bit of battery power to start the motor, so if your batteries are less than half full you may not have enough voltage to start the motor (standard AA batteries are rated at 1.5 volts, but as the energy is depleted the voltage drops). A few times I turned off the adapter to save power and when I turned it back on the motor didn't vibrate. The first time this happened I panicked, because I switched to new batteries and the motor still didn't vibrate. Later, when I researched online, I found out that the motor might have gotten stuck and that I should point the adapter straight down, then turn it on. I then tried that and it worked very well for me on multiple occasions when I had to switch batteries.
To summarize, here are my battery tips:
1. If you are on a movie shoot that lasts the whole day, just leave the adapter on until your batteries run out. If the batteries are low they may not have enough voltage to start the motor from a stop.
2. If you switch to new batteries and the adapter doesn't turn on, point the adapter straight down and the motor will start vibrating
3. NiMh batteries are highly recommended
Feel free to post any questions and I'll answer as best as I can.
good reveiw marco.I to have the letus flip but have found no issues with specks on my footage.the image is extremely cleane and sharp and have been told by another user who used the red rock with the lettus to shoot a feature that the lettus was the sharper of the two adapters.but as marco said i have noticed the glue.but for me it poses no limatations at all beings that i zoom most of the way in anyway.also all of my footage is letterboxed and if i need to zoom out more me being in letterbox affords me more than enough room.if given the opportunity again to get this adapter or another one i'd still choose this one for the under $1000 adapters.did i mention a sweet filmlike depth of feild.
Letus35FE
Letus35FE
I agree with your assesment.
The one thing Id add is you so need rails to support the adapter. The adapter can wiggle around... I'm talking about the threaded mount that attaches to the DVX and the black anodized part of the adapter. I got the Manfroto Tele Lens Support but I'm unhappy with that and am getting a pair of Cavision Rails that should take care of the issues I have.
You say that it's east to open it up to clean it.
Could you tell me how... step by step. Or post a weblink to the process, if it exsists.
I tried and couldn't figure it out.
Thanks,
Kip
wow, thanks for the in-depth...been researching 35 adapters, and this definitely helps establish the Letus, on my radar.
I don't have the adapter in front of me, but each of the sections held together with screws can be opened up by removing the screws. Starting with the side that connects to your camera, you can remove the screws that hold the achromat in place to remove and clean the achromat. Removing the achromat will also give you access to clean the first mirrors. What I do is shine a bright LED flashlight in and if I see dust I try to hit it softly with compressed air. If that doesn't work you can use a Q-tip gently. Be careful not to bend the mirrors.
The other side of the adapter can be opened as well. Remove the screws holding the black anodized cylinder to the flip part and you can separate the two parts. There will be a macro lens inside the flip part that is held in by pressure. You can lift it out to clean it and also to clean the other side of the mirrors. On the other piece (the cylinder with the GG), you can clean the back of the GG with compressed air. I believe the other side is protected with glass, but from the rear you can insert a compressed air straw through the holes on the sides and the air will bounce off the glass and remove any dust that may be on this side of the GG.
Let me know if this helps.
I agree that you need rails. I forgot to mention this. But the adapter is long and heavy and only becomes moreso with a lens attached. You can damage your camera and potentially drop the adapter without rods support.
the only thing i hate in my letus35 enhanced is the dust. everything else is top notch.
Good job. I was just about to post my own review of the Letus35 Flip Enhanced with some images, but you beat me too it. So I'll just add to your review so people can easily find the info.
I'm in the process of putting together a review chart of all the popular 35mm adatpers. I will start a new thread once that is complete.
And I thought I was the only one. I figured there was a glitch and I was planning on email Quyen, but didn't want to part with the adapter. I turn mine to the side when that happens and everything starts vibrating again.
For those that want some grabs, here are two shots. One with the motor on and the other with the motor off.
LETUS35 FLIP ENHANCED - MOTOR OFF
LETUS35 FLIP ENHANCED - MOTOR ON
I'm using a Canon 50mm 1.8 lens with the DVX100A on indiRAILS (cheaper than Cavision) coupled with the indiFOCUS follow focus system. The Letus35mm Flip Enhanced can work without rails, but it get to front heavy and like others have mentioned it could eventually fall off or damage your camera threads.
Very nice images! Thanks! By the way, how do you like your IndiFocus? I was thinking about getting one.
Still haven't had a chance to prepare some grabs but I'll try later tonight. :)
Love it!
I was pissed that all of the follow focuses on the market were so damn expensive. Some costing more than I spent on the camera. I even thought that the indiFOCUS at $389 (with the gears) was too much.
I mean, when you think about , what a follow focus is? You turn a knob and that turn a gear that turns your lens. Simple. But then I looked into making one myself and realized that it would cost a lot of time. More time than I wanted to spend, so I reluctantly shelled out the money for the indiFOCUS.
It was money well spent.
If you have the money for the indiFOCUS, DO NOT hesitate.
Here are a few screen grabs. Image #4 was with the adapter off when I didn't know the workaround to turn it back on when the motor gets stuck. You can tell because it's a little grainy.
Canon XL2
Canon FD 1.4 50mm
So this is a dumb question but im trying to figure out... is this product (FE) good to go with just a lense and some rails? Is it just for flipping other modules that are upside down? Thanks for the info but my research has given me contradictory answers!
I owned one, and I would not use it without rails. Aside from the weight on the lens the adapter can slip off the achromat if you are not careful.
Also unless you want info for a second hand adapter, i am almost certain Letus does not offer the FE anymore.
