Jason Ramsey
Admin
Ok. First: Has anyone noticed the following with the recent upgrade to 4.1 Broadcast - Whenever I do anything DVD related in the output, either an m2p or .vob or a burn. When the process finishes I get an error message and ProCoder closes down. The output/burn works fine and the error does not occur until after the procss is finished, so it's not a huge problem. Just wondering if any v4.1 folks are experiencing the same.
Also, unrelated to v4.1. This has occurred since my first install of Edius (v4.02) - Probably 9 times out of 10 Quick Titler displays an error message that it cannot be run when I start up Edius. This, again, doesn't affect me too badly, as I have been using Title Motion Pro. Anyone experience a similar issue?
Regarding a white balance/color correction, etc. across all clips: I could swear I have done this before, but I apparently don't remember how. I will select all of the clips and can successfully apply a white balance to all of the clips. However, when I go to customize the setting of the White Balance, those changes are only applied to one clip and not all. What obvious step am I missing?
Regarding placing the same person in the same scene more than once: Is doing a 3d picture and picture the recommended way to accomplish this? For example, I am sitting in a chair on the left side of the frame, and am sitting in a chair on the right side of the frame. I have accomplished this with 3d picture in picture by having the clip that 3d PiP is applied to blown up to 100 percent, cropping half of the image, and lining it up appropriately. Would this be the recommended way to accomplish this, or is there an easier, more appropriate, and more precise way?
Some pretty basic quesions, I know.
Thanks,
Jason
Thanks,
Jason
