Which lenses adapter do you recommend for a HVX200?
drcoffee2
Hi there,
My work has just bought a brand new HVX200 + Fs-100.
After seeing the short film ‘Illegal’ stills/footage
(http://www.dvxuser.com/V6/showthread.php?t=71299) I was blown away. I wanted to make the most of the HVX by trying to recommend a lenses adapter to them. I’m very new to this. I wondered if the Redrock M2 adapter used in 'Illegal' was the standard, or if there were similar competitors.
I’m UK based also so hoped there were some UK firms.
Many thanks
Regards
Jon O’Neill
there are several options for you.
do a quick search for:
brevis
sg pro
letus FE
you already know about the m2 but there is a ton of other footage out there with it
go 35
and some you probably wouldn't but, but rent
p+s
movietube
each adapter has it's own pro's and cons and have been discussed at great length (check out the m2 vs. brevis thread below)
there are a lot of factors to be aware of:
set up time
light loss
flipping
characteristics of the "bokeh" and whatnot.
also, the sg pro is uk based.
Matty, I've done a quick search for the 'm2 vs. brevis' thread you recommended but I cant find it. Could you paste its again please.
Regards
Jon
