I know im going to get allot of replies saying, yes you can, or yes if you have a HD external monitor you can.....But what about this?
If i open a clip HD clip in FCP and without touching it export a non compressed QT and than open that QT in QT pro, it looks significantly different than the same clip in FCP.
If on the other hand i open this QT in final cut and view it next to the original clip it looks identical. What does this tell us? - that QT displays colors differently than FCP.
If i now burn this QT to DVD and open the DVD window next to the ORIGINAL HD FILE in FCP, the exported QT in QT pro. I have now three different windows from three different applications (FCP, QTPRO, DVDPLAYER), all on the same monitor, displaying the same clip in three different formats.
Now the punch line -
They all look different!!!! But how?????
I totally understand that colors will change as things get compressed or changed from one format to another. I think the difference between the QT and the DVDPLAYER version illustrates that quite well. The compressed DVD clip is slightly less saturated slightly lower contrast, less sharp and some compression noise is visible. I could live with this. Now on the other hand the original HD clip on the canvas of FCP looks vastly different, it is less magenta, slightly darker, significantly more saturated, more contrast......all in all very far from both the DVD and the QT pro clip.
Why is there so much difference?????? And why so few comments on this?????
It seems to me to be a major problem that a there is so much mismatch between two different pro applications FCP and QT-pro. Yes i know that FCP is not a color grading application, but it really is quite useless for any half serious color grading at all, as you are grading blind, or you have to export to QT after every small adjustment to se what you are getting. Also this means two different grades, one for computer displays and internet and one for dvd.:zombie_smiley:
Now back to the HD monitor. Can anyone that has an actual HD broadcast monitor check this???? Try compare the FCP clip on the HD monitor output to the QTpro on the computer monitor. Check if the FCP clip matches as closely to the QT as the DVDPLAYER to the QTPRO. Even if they are still three different versions, this would mean it was workable, provided one has a HD broadcast monitor. I seriously doubt this will be the case though.
On a side note. When i say different, it is not like in your face completely different, and i could see how one could not notice this. It wasn't before i had color graded for a week straight that once i saw the QT, i was like wait a minute what the FCK.
I hope someone has a solution as i just did a weeks work for nothing and am depressed like hell that FCP performs so badly in this department. Please tell me im wrong!!!!!
