How to I import both audio and video together. Or do I have to import seperate then put them together in the time line? How does it work....can you get them together?
Playback stopped means that for whatever reason, the video could not be processed in realtime.
Usually this means:
a) You're doing too much filter/effect-wise (CPU bottleneck)
b) The data can't be retrieved from the storage fast enough (disk subsystem bottleneck)
c) Some other process is eating CPU time and/or RAM (or you simply don't have enough RAM)
If you're not using filters/effects, then it's usually b.
