Jay Rodriguez
Coffee Member
I'd like to work in FCP to do all of the audio mix down, but wasn't sure if there was some type of audio console in it. What programs do you guys use for audio?
You can use the 3 Band Equilizer in FCP, but I'd use STP, as it has a larger selection of filters to help out.coffee said:hey Ben,
Is there a way in FCP to tune down the bass in a voice?
Also, if you double click on an audio clip the window for that clip opens up. In that window I see two meter bars, one for the Pan and one for Level. I'm assuming that the pan is for left/right pan and Level is for overall volume levels, is that right?
Ok, so if I bring the Level all the way up then the audio for that clip should be maxed out correct? If needed, how can I boost that volume even more? Is there a normalize option somewhere in FCP?
