Dennis Wood
DVXuser Sponsor
Rez, with regard to what you're suggesting, it would be worth exploring. However, I suspect it would be better to machine an interface between the 60mm macro lens, and the camera body rather than using all those adapters. I'm assuming you've already researched using the macro lens as a relay as I have no idea if that would work. The best thing to do, particularly if you own the macro lens, is to set it up on a test bench. An adapter can be represented by just a 24x36 frame in this setup, so all you need to do (sounds so easy doesn't it?) is get that frame focused on your cam's CCD's via the relay. You can email me if you need some help setting up an experiment or two.
