fixitinpost
Ok, so since the contest site is going down soon for maintenance, I'll post it here.
Several people expressed and interest in knowing how I created the final image, so here is a brief explanation:
1. Shot with Canon 30D and 17-85mm at 17mm f.4
2. Color: All color work was done in the RAW adjustments
3. Attempt Photomerge. It failed miserably.
4. Correct optical distortion (available somewhere in the filter menu).
5. Put two adjacent source images on large canvass. Adjust opacity of one layer so you can see through to the other, and use "free transform" to line them up.
6. Create a layer mask on the top layer.
7. Use a brush with about a hardness of "7" to paint on the mask to blend the two images.
8. Repeat 5-7 for all source images.
9. Crop to taste
10. Dodge and burn to bring out details (didn't actually do any burning on this one).
11. Somewhere in there throw in some clone stamping to totally construct the upper right corner.
The full res TIF file is 300-400MB. 8x18" at 300dpi.
Thanks so much for all the feedback on that, as well as on my other images.
9. Crop to taste
