preciousppo
Is it acceptable to use the histogram as reference if the software you use for Color Correction does not have a waveform monitor?
Thx!
Thx!
Histogram and waveform monitor tell you different things. Histogram summarizes values for the entire image: usually luminance values 0-256 horizontally and the relative quantities of pixels with each value vertically. Waveform monitor shows you all of IRE concentrations for each vertical image segment. Completely different pieces of imformation.
I'd probably have to say Waveform, if you could only use one.
You can always color correct in post, but if the original image is way too dark you'll introduce noise trying to brighten it up...
..and if it's too bright, you lose detail in the overexposed areas.
Personally, I'd rather have a perfectly exposed clip with messed up colors than the other way around.
