Round 10 - DVXUser Photography Challenge
I don't have a damn thing. I've been sick for about the last week. It's 30 degrees outside, and I haven't felt inspired to shoot anything.
I went out shooting today and didn't get much, but had an interesting experience. I'll share after the contest since the story might make it too easy to identify me with my entry.
For the uploading please go to:
http://www.stffilms.com/upload
File size is limited to 3MB so if you are uploading an original or adjusted file that is larger than 3MB please resize the image.
When you are uploading it is very important that you format your images in the following manner:
Your original image should be USERNAMEORIGINAL
Your adjusted image should be USERNAMEFINAL
If you are uploading more than one original image please use the following:
USERNAMEORIGINAL1, USERNAMEORIGINAL2, USERNAMEORIGINAL3
Examples: JeremyOrdanOriginal.jpg, JeremyOrdanFinal.jpg
If you are uploading multiple entries then please title as follows:
USERNAMEORIGINAL_FIRST, USERNAMEORIGINAL_SECOND
USERNAMEFINAL_FIRST, USERNAMEORIGINAL_SECOND
Examples:
JeremyOrdanOriginal_First, JeremyOrdanFinal_First, JeremyOrdanOriginal_Second, JeremyOrdanFinal_Second
Please understand that for all the admins involved in this process it is a lengthy process to set this up and only with your assistance can this really work. Thank you very much for understanding and complying and then understanding... We will delete any files that do not work with these methods.
If you need assistance with resizing an image please contact me and I will assist.
Thanks!
Jeremy,
To clarify, we can show nudity that is not pornographic and doesn't show the genital region (i.e. legs crossed)? Because today I read Jarred's forum guidelines and he directly states no nudity in pictures posted.
-Shawn
Examples:
Thanks!
As per stated previously, we're supposed to upload one image straight from the camera. Another after post. Both at full resolution. Full resolution is...much larger than 3MB.
What's the file size if you save them as jpg?
Oh crap! I uploaded the wrong Final image! Uh, what should I do? I need to resubmit my final image. If I simply upload the real final (which will have the same name as the earlier, wrong final) can you make sure to throw out my first final image?
Then resize the images... hence where it says:
or reference this post:
Now onto Shawneous' Question
Contact Steve_Arm and he can delete the image or adjust it at least. Right Steve?
I'm having trouble with the digital camera. Shoot! I hope I can fix it before it's
too late.
