FW port protective housing and L-Shaped FW cables
mark.burton
Since getting my Firestore one thing has concerned me more than anything else - breaking, bending or snapping the FW connector on the HVX200 because you have to have a FW cable sticking out the side all the time.
In all likelihood this plug is going to get knocked at some point when you have a FW cable constantly attached during shooting.
I see the solution in two ways:
1 - Get an L-Shaped FW connector so the conector/cable protrudes a minimum amount.
2 - Design and make a small, thin metal 'housing' to cover the protruding cables. This housing could potentially be attached to the camera using existing screw locations and would therefore be pretty secure.
I like option two but there will be a few considerations with regard to having to remove/replace screws from the camera (I see three which I would initially design this around) and whether this would void your warranty. Second it would need some rubber padding so it sits comfortably on the body and does not damage it. Third it seems all 4 pin FW connectors have varying lengths - the design would need to be big enough to accommodate as many as possible. Four it must not hinder any other function of the camera, such as rubber port protectors and the record button.
An L-Shaped FW 4 pin connector is by far the simplest and the cheapest option. I haven't found one yet, anyone ever had one or seen these? Also it needs to be a good quality cable as the FS100 can suffer if its low grade.
If the L-Shaped connector/cable is available thats the way I'll go, but if not, then I'm going to have a go at making the port protector housing. In theory this could be quite easy and very cheap to make, but I'm no engineer :-)
Would anyone be interested in such a housing?
Having searched under 'L-Shaped' I did not get anything on google that was relevant, but searching under 'Right Angle', I found there are quite a few and it seems Focus have even offered these in the past for the FS3.
Example (found from DVXUser http://www.dvxuser.com/V6/archive/index.php/t-56399.html):
http://snipurl.com/ql7q
So this looks like a good solution for now. Going to keep searching. How does one tell what grade the cable is?
Mark
Still not found a single right angle FW cable - Focus said they would look into it, which doesn't mean much. Anyone have any new leads.
Mark,
I just went to www.tecnec.com and did a search for "firewire" than selected cables. There are several examples of right angle firewire cables on that page. whether they are what you are looking for... I don't know.
Jim
In the end I found this shorter cable and ordered two. They arrived today and I'm very pleased.
The 4 Pin end has a right angle connector, so it no longer sticks right out but sends the wire neatly down the side of the camera. I only wish it had a right angle connector on the 6 pin end too.
This is exactly for sort of wire Focus should have shipped with the unit IMHO.
Mark
Did anyone ever find a good source for a right angle firewire for the Firestore to the HVX200, and if so, did it work?
Michael
I bought a 15-foot right-angle Firewire cable from Markertek, works perfectly and keeps things tidy both on the camera and my Toshiba laptop, which has the Firewire port on the right side.
Now instead of sticking straight out, the cable runs along the edge to the back, and on the camera it drops straight down. 4.5 meters / 15 feet is the maximum length permitted by the spec without breaking the electrical and timing requirements, anything longer may require repeaters to work reliably.
I believe I met some guys at NAB last year who were running 50' and longer FW cables without a problem. It was in one of Douglas Spotted Eagle's DTE seminars.
Yes, but not at DVCProHD (100Mbps) speeds. All of the extended-length Firewire cables are for use at 25Mbps (DV/HDV) speeds, they are not to be used for high-speed devices like hard disks or DVCProHD.
