Hello folks,
I'm considering an inexpensive and practical way to transfer my footage while filming around town / in exterior locations where setting up Powerbook - for xfers everytime my two 4gig P2 cards are full - is just impractical.
I can't afford the P2 Store or Firestores so please don't discuss them in this topic.
I have two LaCie TB drives that I use via my Powerbook for interior location work and for editing my projects.
However these are not practical for about-town filming where often a park bench or a window-sill is the only place to pause for transfers.
Barry mentioned before that there's a 60gig limit for Hard Drives when transfering 4gig P2 cards by host mode - anything above that capacity is a waste - quote:
"if you're using 4GB cards, the biggest drive the HVX can use is 60gb. Any capacity beyond that will just go unused."
Does this mean that the HVX-200 will transfer 15 seperate times to one 60gb hard drive using 4gig cards? How does it indicate that it has reached its capacity for recording to that drive after 15 xfers?
Anyway, that would give me 60 minutes of best DVCproHD footage per drive which would be enough for most of my daily needs when filming like this.
So I'm considering this option - a battery powered hard drive enclosure (Cutie DX HD-254UF+ with Built In Power) and a couple of firewire 60gb hard drives that can be swapped in the same enclosure to give me approx two hours of filming exterior before I need to set up the Powerbook.
However, I'm not sure about the techy stuff because there's a note on the Cutie DX sales website that says, "AC Adapter is included for all customers that use 5400 or 7200RPM Notebook/Laptop Drives!" so does this mean that it will not run battery powered using drives in it that are 7200rpm speed?
If so, do I not need this speed of drive for making transfers in host mode?
Another option I've seen advertised is the AMS 2.5" Rechargable FireWire enclosure that claims to have over ten hours of battery before recharging necessary.... can be used with the IBM 80G Travelstar hdd.... anyone know anything about this possible combination?
What 60gb Firewire drives will work in this enclosure when battery powered?
Will the HVX verify transfer success when using these FW hard drives?
Will the drive enclosure battery be sufficient to make the 30 transfers from my 4gb P2 cards to fill both 60gb drives and give me that 2hour recording while filming about town?
Thanks! for any advice that users with this kind of set up can give me or about any other battery power FireWire 60gb drives available for this kind of set-up.
