taubkin
Alright...
I have an idea. Let's see if I'm being a total fool.
DV Rack is a great idea. Or just using a laptop on field to assure that you are getting good materialwith the help of scopes, audio levels and etc. Or just using it to have a very fast and agile video assist with you (and pretty much lighter than carrying a 14 inch combo VHS around). Since a DVCAM prtable recorder is around the same price (if not more expensive) than a suitable notebook to do the task, and with a much smaller screen, this is what I have so far:
I get a Pelican case, large enough for a 15 inch screen notebook and a couple of extra features. Build inside the case a hub for firewire connection, video out and power in, 110V. So I can put any laptop I want inside and connect it to firewire, video, and power without having to take it off the box.
I build inside of the case an inverter that makes this 110V AC port to come out a 12V battery. Cut a hole in the case and install a firewire port in the case that comes from the hub>computer and a canon 4 pin battery in that will power my 110V (that will power my laptop AC adapter - I know, dumb, but will make it able to support any type of laptop). I add to that interface, whatever other I/O that might be useful to me, maybe a A/D video converter so it can take BNC in and out and extra FW or USB2 or DVI (for external digital monitors).
I put a laptop inside connect everything i can in the laptop and end up with a video assist unit that I can carry along with camera gear (digital video or high end film stuff), and have a unit free of cables dangling, adapters, need for power plug that I can use both digitally (to monitor/record digital video) or analogically (as a fancy video assist for film cameras).
Isn't it a sellable product? (I'm only saying because I lack the engeneering to actually make it work...)
Wouldn't that be worth around 400-500 dollars (if well made and with a built in A/D video converter)? Wouldn't it be profitable?
COULD SOMEONE PLEASE DEVELOP IT? - I'll buy...
Cheers...
[/rambling]
Cheers...
[/rambling]
