DavidBeier
dasonras said:This is a silly post. You guys are all stuck on the idea that things should be letterboxed because "they look cool like that."
I have a friend who shot a film on 16mm. When i saw the final cut it had a 1.85:1 letterbox. I asked..."how is your film widescreen if you shot 16mm? 16mm is a 1.33:1 ratio." He said, "because it looks cooler like that."
I see that a lot except it's with 2.35 instead (even though it's still standard 1.33:1 16mm). I wouldn't mind if they really had a reason to do it. If they felt they compositions would work better. That isn't the case though with the one's I've seen. They shoot regurlar 1.33 16mm with no tape to show them were 2.35 would be and then just crop it to that in post because, "it looks cool!" If you can cut off almost half your image in post just as an afterthough then you either didn't compose right in the first place or are screwing up your picture now.
