I've been doing post on my feature that was shot with an HVX200. We shot most of it at 1080/24pA, with some 720/24pN shots at variable framerate. The sequences were all set up at 23.98fps. I imported all the clips with 5.1.1 about 4 weeks ago. They all showed 29.97fps (except the 720p shots) because FCP didn't remove the duplicate frames properly at the time (5.1.2 does now). I used the Cinema Tools Reverse Telecine option under Tools on all the 1080/29.97fps clips and they correctly became 23.98fps. Two days ago i noticed that all of my clips were showing 24fps in the Browser and the sequences were still 23.98fps. I checked various files in Quicktime and Cinema Tools and they showed 24fps as well.
What's really odd is that almost all the clips open in Quicktime at a smaller size than their actual resolution. Finder shows the resolution of those clips as 640x360. There's a few clips that are duplicated in the Capture Scratch folder that show 1920x1080 as the dimensions. Those clips open at full size in Quicktime. I tried re-importing a P2 card into FCP with 5.1.2 and all the clips import properly at 23.98fps and show the resolution as 1280x1080 in FCP and the Finder. Any idea what happened or what's going on? Is there an easy way to re-import/replace the existing shots so they show the correct information and frame rate?
I noticed all this before 5.1.2 was released. I am now running the latest version of all Apple Pro Apps in FC Studio and Shake. I updated in the middle of the project only because I wanted to see if this would solve the issue or reveal new info, plus I'm doing color correcting and needed the Scopes bug fix. I got new info, but I'm still confused. Any help?
