DammitJanet
Well, I found a few Nikon lenses today, but they were all f1.8, not f1.4, and they looked to be about from the 80's or 90's. The guy said he'd let one go for $40. What do you think?
Wayne Kinney said:the aperture in EOS lenses is electronically controlled by the EOS camera body. With the lens on a 35mm adapter, there is no such connection, and the EOS lens is usually set at wide aperture.
I have heard of a trick that you can attach the lens to the EOS body and set aperture, then remove power of something similar that will keep the aperture where it is, then you can put the lens on the adapter. I've not tried it, though.
DammitJanet said:Well, I found a few Nikon lenses today, but they were all f1.8, not f1.4, and they looked to be about from the 80's or 90's. The guy said he'd let one go for $40. What do you think?
Bionicpix said:Just got a used Canon FD lens. Fits on Letus, nice pic, etc. Question: there is a manual aperture ring that turns, along with a push button marked "A" in green (I assume for an auto setting). When I spin the dial, nothing happens - i.e. the lens is wide open - no movement of the aperture inside the lens. Is there a trick to engaging it? I also have a zoom lens that I borrowed - same deal with that one. Wide open.
deedive said:from what i read most people with adapters have nikon f mounts. What is the advantage of a canon fd mount. Its not like u can buy a digital slr that fd mount lenses will work with? Plus i've seen alot more nikons used. Is the quality better?
snodart said:I'm using a Canon FD f/2.8 28mm and an FD f/1.4 50mm. f/2.8 is a little slow for the 28mm, but can still produce nice images.
Keep in mind that "fast" and "slow" just refers to the lowest f/stop setting. So a lens with a minimum f/stop setting of f/2.8 is considered "slower" than a lens with a minimum f/stop setting of f/2. It doesn't mean much more that that.
If you do end up going with Canon FD, there is a little "trick" you will need to do with some FD lenses to engage the f/stop lock lever.
The lever above is normally engaged when attached to a camera. I just cut a small piece from some from brass flat stock (hobby stores), cut it to length, slid the lever over, and inserted the brass piece. Easy fix and works fine. I had forgotten it was even there until you mentioned FD lenses.
Good luck
Bionicpix said:The small, round white dots? Those are automatic floodlights going on, as it's nightfall. The ones behind the telephone poll are bright lights at a basketball court for a school back there. Or were you seeing something else? Those are taken at full zoom (205mm). Wasn't really "locked off" or anything, so there was probably some movement as I was just panning around.
