ripupthehwy
:badputer:
HI all,
This is the 3rd computer I have set up with premiere that has some audio problems. I have 2 other friends who also agree: "2.0 has issues"
As long as you are doing simple editing where you don't have to apply alot of effects everything seems hunky dory (good). Otherwise, heavy tasking causes audio to not play back perfectly (audio pops, drops in clip volume leves, loss of audio affects previous applied)
My newest system, with 2Gig of Ram, a 512mb DDR3 video card and Pent. D 3.4ghz cpu SHOULD be stout enough, but alas, I still have problems with heavily edited projects.
I'm editing a television drama show. There are lots of clips that had background hiss that had to be filtered out and clips with low audio that had to be raised.
When I play the entire movie from the timeline, almost every other edit point (cut to a different clip) results in a loss of the applied audio effect/filter or a drop/loss in the audio volume for about first 3 seconds of the clip. If I stop the playback, back it up and re-play the individual clips, they play fine. Resume playing entire movie, and again, the short drops in audio volume or audio effects.
I did not have these problems in Premiere 1.5. Will we EVER see any updates to Premiere 2.0?
On a final note, I installed a DEMO/Trial version of Canopus Edius, Imported the same clips and applied similar effects and they all played beautifully. What's up with premiere?
Choosing "compatible" or "enable GPU effects" in the playback settings in premiere makes no change.
Any thoughts from the seasoned Premiere editors on here would be GREATLY appreciated.
ripupthehwy@yahoo.com
HI all,
