puredrifting
Major Contributor
Hi Dammit:
There is absolutely nothing crappy about the DV-1. The DV-1 is an entry level product though and for a larger (small) camcorder like the HVX-200 (assuming that is what you have?), it exceeds the weight limit on the DV-1, which is rated at 4.4 lbs maximum. The DV-1 is made for smaller consumer/prosumer camcorders, not the HVX-200.
You would need a minimum of the DV-2 to support an HVX. But wait, if you pack on a FireStore, large battery, matte box, filters, soom control, etc. you will exceed even the DV-2's 6.6 lb maximum capacity.
See how this works? You need to look at the camcorder package you are using and mentally tally EVERYTHING you might ever want to use on it. If you have an HVX, do you ever want to add an M2? Rods? Follow Focus? Say you end up with a potential maximum weight of 14lbs. Better get something rated at 16lbs max weight, that way you have some cushion in case you exceed that. What if you have a FireStore today but decide later to trade that in for the CinePorter and the CinePorter weighs more?
Once you have determined the maximum weight, then look at ALL of the available choices, from cheap to way more than you want to spend. Compare quality, features (know what a lighted bubble level is? Once you do, you will want/need one) and reputation. Rent a few models and try them out or take your camera package to a dealer who will let you try them out on the showroom floor with your camera. Make your decision using your head, not your wallet. Once you decide THE tripod for your needs, then worry about what you can afford. If it turns out you need a $3,000.00 tripod for your needs, you will find a way to buy it.
Assuming you are a professional, buying products like camera support using a criteria like "is it cheap enough?" and "can I afford it?" is the wrong approach. If you can afford an HVX, editing system, carrying case, lights, sound gear, etc. you can afford a professional tripod. If you make your living with this gear, buy something professional.
If you are a hobbiest, disregard all of the above, buy whatever you want, because in the end, it's just for fun, right?
Best,
Dan
Best,
Dan
