Daniel Wee
I finally got my hands on the GO-35 Pro adapter and am in the process of familiarizing myself with it for a shoot but also testing it's performance. This is the first part of my test, basically to see how the general feel of the adapter performance is like.
There is nothing to complain about the construction of the adapter itself. It is well made and seems to be sufficiently rugged. It came clean with no visible dust specks inside the system so that's good news too. The achromat comes as a separate unit so you have to screw the adapter and the achromat together before using. This is trivially simple and will only take a minute to figure out (or less).
Light loss is a bit more severe than I had expected but I will test this more thoroughly under controlled conditions in the second part of my testing. Sharpness is noticeably lower than without the adapter. Bokeh is good and there is no noticeable fringing or chromatic aberration. Grain has not become a problem yet in my testing. My biggest complaint at this time is the light loss but we'll deal with that later.
This footage is a bit jerky as I was not using an external LCD or the flip hack. Basically I was trying to look at the LCD upside down and as a result fumbled a bit with the panning. I also did not have rails on but simply supported the extension with my hand. With rails, LCD, and the adapter, the whole thing can be very heavy and cumbersome, and not really suitable at all for handheld operation.
Here's the clip - give it some time to load. It's about 25MB and will not auto-play so you need to click on the play button once you've loaded enough of the stream to get it started. It was shot at 25p using the recommended settings:-
Detail +7
VDetail +7
Detail coring +7
Chroma level +7
Master ped -5
Cinegamma D
Cine matrix
Skin DTL ON
This was the given settings in the instruction sheet. The focus settings I used was MF30 and Z79 but the instructions said MF20 and Z73. I'll have to test that to see if I can get better performance with the recommended settings. It does say though, that the settings may be different between the DVX100a and the 100b version. I am using the DVX102b which is the same as the 100b.
The idea width for viewing this clip is around 640. You can size the window accordingly but if you get too large you will see pixelation. So 640 is the best horizontal resolution for viewing this clip (shot in SQUEEZE mode for 16:9 aspect ratio).
http://blog.tsebi.com/video/GO35Test1.swf
Feel free to ask any questions you have or if you want specific tests done.
Daniel Wee
Detail +7
VDetail +7
Detail coring +7
Chroma level +7
Master ped -5
Cinegamma D
Cine matrix
Skin DTL ON
Daniel Wee
