Rubix³
Hello
I had this problem with my last capture, but using "capture tape" got rid of it. This solution doesn't work now.
What happens is this: I will bring up the capture window, play the footage, and both the audio and video stutters at the same time. The latest footage I have has industrial fans in the background so it's very easy to tell. It'll go "raaaaaaaaaaaa-ta-ta-ta-ta raaaaaaaaaaa-ta-ta-raaaaaa" (the "raaa" being ok, and the "tas" being the stutter) and will stutter the video along with the "tas." Because of this, I believe it's an audio-driven stutter that affects the video.
This doesn't happen if I play back through my TV.
It happens with both my deck, a dv53, and through the DVX.
I changed my pagefile to another drive (not partition) from my video drive and that didn't fix it. I have my prerendered & temp folders on the video drive, and tried it on a different one.
My computer is a P4 3.2C (Northwood 800FSB HT, not overclocked) on an Abit IC7-G and I have a gig of Corsair XMS-3200 ram. All drives are 7200RPM IDE on an ATA133 card. I have never had HD performance issues.
If I capture through Windows Movie Maker, it works fine (is this the same result as capturing through vegas? even filmed at 24pa?)
My footage is 24pa, and my volume was monitored and at an acceptable level. Onboard audio, no mic.
I use a belkin firewire cable and I tried two different firewire connections (directly on board, and from PCI firewire hooked up to board).
edit: I do not run antivirus software automatically, my XP installation is fully tweaked (14 default processes) and spyware free.
What do you think?
What do you think?
