I shot my film on the panasonic dvx100b. We used squeeze mode (for anamorphic) and 24p advanced. I am editing on a new intel mac with ample memory and the recent version of final cut.
We are currently test capturing clips and having problems. Here is what I am doing:
1. Set the sequence settings to "dvntsc48-24" and "anamorphic." Since this isn`t one of the settings that comes with the program, I make my own using the duplicate feature to add anamorphic to the preset settings for dvntsc48-24. (I`ve also tried using 23.98, but it doesn`t seem to make a difference with the issues we are having.)
2. Set the log and capture settings to "advanced pull down removal" adding anamorphic when I customize the setting.
3. I then capture test clips. I move them to the timeline and they appear with red lines (need rendering). That seems wrong...there must be a problem somewhere.
Also, I am running a dv signal out to my camera and then via rgb to my pro ntsc monitor which has as 16:9 button. On that screen they appear to have been doubly unsqueezed, so I unpush the 16:9 button and they seem normal. Is that right?
Thanks so much for considering these questions. We are based in Panama without much support nearby.
