how do i remove pulldown?
ddent
I shot 1080/24p and started a project on Broadcast trial 3 under 1080/24 over 60i, however, I am getting a jittery image and jagged lines. How do I remove this. Even when i export to a quicktime or mpeg file it still shows but is not as noticeable as on my timeline.
Thanks for the help
That's odd. If you shot 1080/24p and are in a 1080/24p over 60i project, the resulting 24p output should be OK.
However, since the hardware output rate is 60i, you'll see "artificial pulldown" as the hardware output is still 60i.
Alternatively, you can try one of the OHCI 24p projects, but you won't get hardware output.
