Disabling frame blending?
J5 squared
I've got a few clips with ramped up motion and the frames are blending and its quite noticable. How do i remove frame blending on the clip?
for your info ... if you have the Vegas preview window set to "preview" it does NOT resample any clips ( even if resample is checked) when you view clips ... if you set it to "good or best " it will resample as you view ...
It will when it renders, though -- preview settings don't affect render, and that includes bypassing the effects in the preview.
No it doesn't. This is a setting under each clip. Once you've turned it off it stays off and it doesn't render it out. It has nothing to do with "preview"
